Torqueflites are supposed to pump in all gears and neutral but not in park. That's why the stick says to check hot, idle in neutral. A way to check if it's pumping in neutral is to check your fluid level in park, then do it in neutral and see if there's a difference. Level should be higher in park.....and that's a cool looking ride you have!!
