Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
  #270 (permalink)
Old 06-29-2009, 09:26 AM
knighthawk knighthawk is offline
after tghese 2 short runs to the car shows, a few things will needed to be redone ... first,before I could leave for the show Sat. , the gas tank was leaking, at I seam where I cut the tank open and soldered it.. The brake problem, which by the way, the pads are now burnt and junk, and the suspension is not right, I guess I misfigured the wieght load when I "designed" it. So.......first, I guess I got to get some pads, calipers, and rotors cut, and of course they are 1 piece hubs, so it's a little more work.........plus maybe another set of seals........
