Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
  #271 (permalink)
Old 07-01-2009, 09:15 PM
knighthawk knighthawk is offline
found the brake problem... the brake pad was worn unevenly, one end was wore down 1/8''more thanthe other end, and when the caliper piston comes outward under pressure hitting the uneven pad, ***** the piston and locks it up. Then after a short while after pressure is released somes times frees up, other times stays tight ....after installing new hubs/rotors, calipers and pads, and a road test, all is fine !,,,.........now..on to the suspension........
