Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
Old 01-09-2007, 05:10 PM
knighthawk knighthawk is offline
I'm thinking, I need to keep the '' B '' pillers straight, lenghtening the roof is a good idea. The rear window is the problem that I can see ! There's not much room around it , especially the bottom, to get the hump out. Homebrew, have you ever chopped one, by cutting out the roof tin before you start, then building it , more or less, with just a frame ? as long as it would get cut up alot by streching and widening. Then just put the tin back on, and fill in where it's short.
