Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
  #51 (permalink)
Old 05-02-2007, 02:29 PM
knighthawk knighthawk is offline
progress
speaking of progress, I set the seats in , to find the center for the steering and brake pedal..Where I'd like to put the pedal, it will not line up with where the booster will fit, cause of the column. Where the booster fastens to the master cylinder will have to be a few inches higher than where it was originally ,. Question : Instead of messing with the pedal arm ( too make it longer, and mess up the ratio ) should I re- do the linkage to the master cylinder ?
