Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
  #180 (permalink)
Old 05-19-2008, 06:31 AM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by knighthawk
so, I'm putting the battery in the trunk , have to run a battery cable forward. Also want to re-route the harness that usually goes along the door sills(seats and taillites ). I'd like to put them on or along the tranny hump, but then I'd have to splice and make them longer.... BUT... I've been told put them UNDER the car and run them in or along the frame rail. Any suggestions ??? Road salt would not be an issue, just maybe water and mud ????????
You should keep the battery cables out of the car for sure.Water and dirt won't hurt them.
As for other wiring under the carpet, should be okay as long as you don't use oversized fuses.
