Another cooler line question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2006, 09:12 AM
Ive searched around and read some other posts but didnt really see what im looking for. I recently purchased a TCI streetfighter TH-400. The tapped holes in the case for the cooler lines are 1/4" NPT ? correct. Where as the factory case has the inverted flare fittings. My question is would I be able to use these adapters
http://store.summitracing.com/defaul...-72001&FROM=MG
Then finish off with 5/16" steel line? I would think this adapter would restrict the flow. Any recomendations or input is greatly appreciated
Old 03-26-2006, 03:25 PM
airworld2's Avatar
fittings
any ace hardware should have the same fitting in the picture. and price is better.......
airworld2
Old 03-26-2006, 03:35 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I go to a local NAPA store for the more common needed brass fittings I need as the other parts places don't carry much or the rpice is too high. The local hardware store (True Value) has a HUGE selection of small stuff but not most of these type adapters.
The price of that fitting is higher than local, plus they will add a packaging and handling charge.
Old 03-26-2006, 04:09 PM
Most transmission shops have LOTS of General Motors transmission cores....and will GIVE you some if you act nice....
That's where I get mine....
C6 transmission cooler lines question? Steve-0321 Transmission - Rearend 4 02-04-2006 01:04 PM
Fuel line question stea Engine 8 06-01-2004 04:59 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 06:07 PM
Fuel line question Camaro2Fast4u Engine 5 03-07-2003 07:12 PM
