Another differential question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2004, 05:00 PM
SAATR's Avatar
Last wiki edit: Header design
Last journal entry: And still more pics...
The build sheet on this 78 gmc pickup that I've been looking at has an RPO code G80 - Rear Axle Locking Type, and I was wondering if this meant it was a posi axle or something else. In case you didn't read my previous thread, it's a 78 gmc 3/4 ton, 14 bolt rear axle. Thanks.
Travis
Old 04-27-2004, 06:06 PM
DoubleVision's Avatar
a locking rear isn`t what the name says, this is where many get confused on rear types. The factory never installed a locked spool rear in any vehicle, as it wouldn`t be very safe.
what your rear has is a limited slip differential, "posi traction" is just the GM name for it, they use clutch packs or cones, so that in a straight line, both tires apply traction, but in a curve one side free wheels and the other turns. Ford used limited slip differentials and called them "traction lok" Chrysler also used them and called them "sure grip" differentials, another GM name was "Safe T Track" In most cases on GM vehicles they have a tag that says "use limited slip diffential fluid only" and this confuses people even more, they add the regular fluid that you buy at a parts store that says it works in limited slip diffs, and the rear chatters and pops like crazy, then they think the rear is no more good so they change it. These rears require GM additive which you can buy at the GM parts counter for around $11, it comes in like a 6oz bottle and cures the chatter and pop problem, but if you buy red line synthetic or royal purple synthetic diff lube, the additive isn`t needed.
Old 04-27-2004, 08:09 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Like DoubleVision said, you most likely have a clutch type differential posi/limited-slip.
I have heard that Detroit lockers came in them axles but have never seen one from the factory, or even seen anything on the internet to prove this either.
It however COULD contain the Gov-Lok centrifugally actuated factory locker, otherwise known as the "exploding locker" as it actuated by centrifugal force counteracting the spring loaded weights and engagement members.
The only positive way to identify which type you have would to be to open the case.
My '82 C-10 also has the G80 code but I couldn't tell you which type of carrier or what gears it has, as I have never removed it.
Old 04-27-2004, 10:15 PM
SAATR's Avatar
That good fellas, at least I can be pretty sure it's got a posi, less to buy down the road. " Exploding locker" eh? That doesn't sound good, hopefully it won't grenade on me. Thanks for the info!
Travis
