Another EGR question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2006, 05:01 PM
This ?, has not been answered in previous posts.
I gotta '85 Pontiac,with 305, It's gotta pass emission test. Took it to get tested, and failed, NOx is high. Indicates an EGR problem, or possibly catalytic converter.
EGR valve is working, clean, and free.
When the car is at idle, and the EGR is opened it should make the engine run rough or even quit. Mine won't. Open EGR and no change.
First thought is Heat rizer in th' intake is stopped up. So I remove th' intake,(hadda coolant leak anyway). Heat rizer is clean and clear.
Getting good vacuum signal to EGR, but when opened at idle, there is no change. WHY?!
At least I got th' coolant leak fixed
Old 05-21-2006, 08:47 PM
DoubleVision's Avatar
Did you check the heat riser in the head itself? carbon can build up into a clot in the head passage also. Have you carefully checked the valve to assure the valve itself is opening? I`ve seen one broken unit where the assembly moved but the valve didn`t since it was broken off. Have you checked the passage that goes into the intakes plenum? Just because it gets to the valve doesn`t mean it`s getting to the plenum.
Old 05-22-2006, 05:21 AM
checked all that. the head is clear, the intake manifold is open and free of debris, the valve is working fine. when open you can blow through it and when closed you cannot. I'm stumped. That's why I posted this question.
Old 05-22-2006, 07:09 PM
cboy's Avatar
Last journal entry: Finished
You mentioned in your original post that it also might by your cat. Why did you eliminate the coverter and concentrate only on your EGR?
Always learning...and sharing what I've learned.
Old 05-22-2006, 11:37 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I think he probably deduced that since the EGR isn't causing a rough idle that it might be the problem.
What I would do... poor man's experiment Take the cats off, or at least loosen them enough that there is a serious leak. Then see if the EGR test causes a rough idle. I can't see why a clogged cat would mask EGR failure but you never know.
Old 05-23-2006, 04:33 PM
kain13's Avatar
i did emissions for six years in las Vegas Nevada.
was the car at operating temp how long did you drive it before the test,does it take 92 octane fuel and you put 87 in it?
Old 05-23-2006, 05:31 PM
Vehicle was up to full operating temp, about a 30 min. drive, the eng. is a low comp 305, High octane is not necessary, However, for the 2nd test, I hadda git gas, so I put in about 5 gal. of premium. (Dam! That stuff cost as much as 100LL, so much for th' STC ). I elected to abort th' test, when apparent that failure was emminent. (that saved my free re-test )
Remember, we're talkin about an '85 Pontiac Parisienne, (ghetto boat).
Old 05-23-2006, 05:36 PM
DEDuced Reconing, Bein's how th' opening of th' EGR did not induce rough idle, I decided that I would check there first. ( cheaper too! )
I'm gonna install a new Cat Converter, an' iffin' it don't pass, it's gonna git a brand new ZZ572/720 crate motor!! (I kinda hope it don't pass)
Old 05-23-2006, 05:56 PM
Egr
hi,check this.Remove the egr valve.Have a helper start the engine,then you be under the hood.Put your thumbs over both ports of the egr passages.One should have exhaust pressure and the other should have vacum,if no vacum is present you are stopped up in the intake manifold.Simple!Good luck
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
EGR valve not working lamothe1 Engine 15 04-30-2003 02:59 PM
