another flame question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2002, 10:38 AM
New Member
Post another flame question
since ive seen two flame job questions,i figured id give my question a go.my question is how do you get the flames to fade off?light spray?sanding?thanks for any help.
Old 03-01-2002, 01:08 PM
Post
How do you mean, fade into another color? That is done like youy said, with light spray.
79monte
Old 03-01-2002, 01:26 PM
New Member
Post
no i meant the same color but thanks for the response,i figured that was the way it was done.maybe 75 percent thinner,and 25 percent paint mixture would do the trick.im just not sure how everyone does it.thanks for the help
Old 03-01-2002, 01:42 PM
jwcnj45's Avatar
Post
You have the right idea about the flame fade out. Start on the area where you want the color to be the strongest and sucessively work away from that point one light coat at a time with the overthinned color. Try some test panels first as some colors do not respond well to alot of overthinning.
Old 03-01-2002, 01:45 PM
jwcnj45's Avatar
Post
Oh I forgot to say do NOT sand between coats or you'll ruin what you started.
Old 03-01-2002, 03:26 PM
New Member
Post
thanks jwcn thanks for the additional help im pretty sure i have it all figured out now.just practice alittle and ill have it down thanks
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Unique Flames Question way_2fast_4u Body - Exterior 5 06-04-2003 03:13 AM
