another head question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2010, 01:40 PM
motorhead454's Avatar
hey guys. I have a debate with my stepdad about heads for my grandfathers blower motor. the motor is a 454 with edelbrock rpm heads and a 6-71 mooney on it. I am not sure of the cam specs. anyway it just got back from the machine shop after he spun the main bearings and cracked the crank. I am not sure of the ratio he is running on the blower right now but my stepfather is telling my grandpa that he needs to switch to cast heads because he says that aluminum heads arent as durable for blower applications. I disagree cause I have yet found a cast head that will out flow the top dawg aluminum heads. Am I wrong or can you find cast heads that will? FYI my grandpa took the cheap route and put another cheap steel crank in it.
Old 07-27-2010, 04:49 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i certainly wouldn't consider those edelbrock performer heads to be a top performer. and if you mean by top performer like a set of like DART Big M, Big Chief, or Brodix Big Duke or AFR Magnum and the higher end canfield heads then you are right you wont find any cast heads that will out performe them but you are also gong to spend 2500-4500.00 (depending on which ones and whether you opt for the CNC porting) and that is before any extra machine cost (i dont believe in "out of the box"). i would somewhat tend to agree with you as BBC's don't have quite the selection of iron heads that SBC's do but if your grandfather isn't running a ton of boost then he would likely do fine with a set of Iron eagles, or Merlin's, they can be had for under 1800.00 easy and then with some machine work they can creat just as much or more flow and velocity as some of the mid level alum heads out there for less money, and certainly better than those Eddie's (sorry not a fan of Eddie heads, great intakes but IMHO that is about it)
IMHO a set of Brodix BB-2plus or DART pro 1's for around 2200-2300ish and then with some added messaging here and there on them would be his best bet. but since you mentioned that he went with a "cheap steel crank" in there i doubt he would be willing to spend 3k on a set of heads, but you have to pay to play
Old 07-27-2010, 06:06 PM
yeah I am not a fan of edelbrock heads either. I am gonna try to talk him into some pro 1's cause i have heard they can be worked over very nicely. if it werent for my uncle getting in the boat and racing people it probably wouldnt have pooped out. Cause the motor is in a early 70's pickle fork eliminator and my grandfather never takes it over 5k rpm but my uncle jumps in and thinks he can spin the thing to 6500 -7k. he is gonna sell the thing but we are tryin to get it running really good.
Old 07-27-2010, 11:28 PM
my87Z's Avatar
i like the Pro 1's i am a big fan of DART heads, that is what i run on my street/stip car now. i'm also a big fan of brodix
Old 07-28-2010, 12:20 AM
techinspector1's Avatar
Wiki Edits: 326
Sounds like Grandpa needs to take Uncle out behind the woodshed and give him a tuneup.
Let me help you out a little with nomenclature. You're using the word "cast" to indicate iron. This will get you into trouble sooner or later. Iron heads and aluminum heads are both cast, unless you are talking about Top Fuel heads that are billet. But anyway, please use either "iron" or "aluminum" when talking about heads.
Old 07-28-2010, 02:37 AM
awww I see ok. I just always associated cast with iron. kinda strange cause I know that aluminum and iron are both cast. thank you for correcting me! But yes uncle needs to be corrected also! lol. easy to break things when there not yours. Now this may be a dumb question but what is the diff between billet and cast aluminum?
Old 07-28-2010, 03:34 AM
Wiki Edits: 326
A billet part starts as a solid hunk of metal from the foundry and the part is whittled out of it, usually with computer numerically controlled equipment. Fueler heads run dry, no coolant, so the ports and such can be cut according to a software program.
A cast head results from pouring liquid material into a mold, letting the material cool and removing the part from the mold. Finish machining would add valve seats, guides, drill and tap for rocker studs, cutting of the surface for flatness, etc.
Old 07-28-2010, 09:18 PM
Silverback's Avatar
Boost Retard
To further answer your original question, iron heads would be stronger if they were cast identically to the aluminum heads, but typically aluminum heads might be cast with deck surfaces 2-3x as thick as iron heads which usually makes up for it.
head gasket question... ourmartyr Engine 1 01-22-2008 07:46 AM
SBC HEAD QUESTION: Need Help Picking A Head Mustangsaly Engine 10 11-30-2007 01:48 PM
head gasket question malibu68 Engine 20 06-23-2007 07:58 AM
Timing question and cylinder head question.. Blackhauk90 Engine 2 05-22-2007 01:10 PM
flat head question mercmama Engine 7 03-29-2005 06:59 PM
