another "help me choose a cam" thread - a saga - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-16-2011, 02:19 PM
Originally Posted by techinspector1
With a 9.8:1 static compression ratio, the motor will want a cam in the 216-218 range on the intake side. This is just a generality, but will help you to see what the motor wants. Here's a chart that I put together. Bear in mind that this is just to get an engine builder into the ballpark of choosing the correct grind......
http://www.crankshaftcoalition.com/w..._compatibility
Thanks ... interesting. So my aspirations to pull hard up to 6,000 are likely unrealistic. One reason I chose the 327 for the 911 was to have something operating nearer the rpm range of the 3.0l boxer I sold out of the car. However, I wanted to be able to use pump gas.
  #17 (permalink)
Old 09-16-2011, 02:20 PM
cool rockin daddy's Avatar
Ahh, I see.
  #18 (permalink)
Old 09-16-2011, 02:36 PM
Banned
Go with about 220 but run it on a wider LSA, about a 112, with about 8 degrees more exhaust duration, it'll give you a flat torque curve from about 2800rpm to 6000. It'll be down on peak torque but it'll hold it longer.
  #19 (permalink)
Old 09-16-2011, 03:05 PM
I like flat torque curve
  #20 (permalink)
Old 09-16-2011, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
He's worried about the lifter travel in the wishbone retainers esp given my bastardized setup.
That would be "dog bone" retainers, but yes- that's the same thing I was wondering about, seeing as how the OEM hydraulic roller set up only allows the 0.354" lobe lift.
BTW, this is one example of where a higher ratio rocker arm would be beneficial. You will be able to add some lift to a milder cam- plus keep the base circle larger to aid in the retention of the lifters by the dog bones- by using a higher ratio rocker arm. This will allow you to have valve lift that would be unavailable to you if you had to use 1.5 rockers with a cam that had a smaller diameter base circle.
  #21 (permalink)
Old 09-17-2011, 07:46 AM
I have used the GM Hot Cam in a ZZ4 350. ZZ4 heads are the L98 Corvette heads, 1.94/1.5. The heads will handle the .525 lift with the LT1 springs. Lobe lift is .328. I thought it was a great street cam, well matched to the L98 heads which don't flow a bunch. A slight lope at idle, would probably lope a bit more in a 327. Very torquey, pulled strong to 6k where it was all done. Would bounce off the rev limiter at 6200 easily. Machined on a billet core, not cast. Just sayin', I don't think you'd be unhappy with it at all. If you're just looking for sound throw a Mutha Thumper at it - jk! Sounds like an interesting beast you've created, keep us posted how it turns out.
BTW, I still have the new unused ZZ4 cam - 208i/221x @ .050, .474/.510 lift. lobe lift .34 - if you're interested. Should be sweet in a 327.
  #22 (permalink)
Old 09-24-2011, 11:54 AM
Measured actual cam specs
I just measured the cam specs in the block (using .050 ref pt):
Intake is .297 (.472 w/1.6 rockers) 265* duration
Exhaust is .303 (.485) w/1.6 rockers) 268* duration.
LSA is 119.5*
I got some pics of the lifters and the dog bone retainer at base circle and peak lift, will upload later. Looks like there is @ 1/16" available space to add lift before the lifter shoulder impacts the dog bone (bumping it up). That's still (1/16*1.6) = .1") if I'm thinking about this correctly.
Opinions on the cam?
  #23 (permalink)
Old 09-24-2011, 12:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
LSA is 119.5*
That wide 119.5 LSA along w/265/268 duration @ 0.050" lift are suitable for a BIG cubic inch and/or boosted/race application.
If the duration is advertised and not @ 0.050", the LSA is still not what you want, but at least the cam would be usable on the street. Not optimum- usable.
  #24 (permalink)
Old 10-03-2011, 08:53 AM
Cam change update ... bearing failure
(Maybe this should be a new thread, but since the same project I went ahead and put it here ... )
Well, the domino's are falling. I have removed the cam and sent it to Midway Performance in PA. He's pretty sure I measured it incorrectly and based on comments here he could well be right, I don't discount it. At any rate I'm going to go with a custom grind because the price is not much if any different than a std cam and I like the idea of getting something that an experienced cam guy devises with full knowledge of all the tech factors specific to my car.
SO ... I pulled the cam to send away, and check out the first journal bearing (see pic). That's weird isn't it? I forgot to take a pic of the cams bearing journal before boxing it up, but it was not damaged (yet).
What is the cause of this bearing damage??
  #25 (permalink)
Old 10-03-2011, 09:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
When cam bearings are installed as the factory, the bore alignment is "corrected" by honing the bearings and not the block bores, so there is a chance the cam bore is a bit off. Check all the bearings to be sure it's only the one.
Some other causes are debris under the bearing, a bent cam, out of round cam journal, an incorrectly made bearing, too tight timing chain, excessive valve spring pressure, oil starvation/oil breakdown/loss of oil wedge (although the appearance doesn't look as though this was the problem).
If a replacement bearing doesn't cure it, the bearing will need to be clearanced to fit, either by align honing, or (gasp) hand finishing.
  #26 (permalink)
Old 10-03-2011, 02:01 PM
cam grinder recommendation
Got a recommendation for 224/236 @.050 with 110 lobe separation "4* advanced". Same as the comp cams 276. I don't know what the 4* advanced refers to.
I'm a little leary it's too much, but now I'm second guessing an experienced cam grinder (who I've explained everything I want to), based on participating in this forum. I said I wanted a hint of nastiness in the cam. I definitely don't want choppy, and if lopey, then not much. More like growly would be what I'm thinking of ... I sound like an idiot! I think he's pretty frustrated dealing with me, and I can feel for him. It's a '76 Porsche not a '67 Z28. I'm really wringing my hands over getting this right.
  #27 (permalink)
Old 10-03-2011, 02:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I think that's as big as I would go w/your 327, given your 'wants'. Is this a flat tappet or roller? What did you or they say regarding the stall speed?
When they say advanced 4 degrees, that means the cam will open the valves a bit sooner and close them also a bit sooner. This tends to bolster the bottom end of the power band. To do this you would use a multiple keyway timing set or use a bushing in the cam gear where the dowel pin locates it on the cam. The multi-keyway set-up is the easiest to use, IMO.
  #28 (permalink)
Old 10-03-2011, 02:22 PM
Hyd roller, manual trans.
He mentioned installing it "straight up" - that seems to imply the 4* will be ground in. I was not planning to replace my roller chain setup.
  #29 (permalink)
Old 10-03-2011, 02:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If that's what he said, then straight up it is, and you won't need to chance the timing set.
  #30 (permalink)
Old 10-03-2011, 09:43 PM
willowbilly3's Avatar
Last journal entry: Body mods
The only advice I can give you is get it running and drive it to a Porsche gathering, it'll drive 'em nuts.
SBC wiki articles: pro, con, and "how to choose" Jon Engine 0 08-23-2009 12:54 PM
Fortypickup Choose "Gassers any year, make model" for February Art Contest !! Only Racing Hot Rod Art 34 02-27-2009 10:33 AM
The "wrong cam" saga update. Jmark Engine 27 01-02-2004 05:09 AM
