another holley carb ID question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 02:01 PM
tab's Avatar
tab tab is offline
ok, here's what i have. i think it's an aluminum, 750 double pumper. it has mechanical secondaries. anyone know anything about it? i like it because it's much lighter than most holley carbs i've found.
ID:	40504   Click image for larger version
ID:	40505   Click image for larger version
Old 09-08-2009, 03:01 PM
ericnova72's Avatar
More for Less Racer
It is a 4010 series if it is square bore, or 4011 series if spread bore. Holley came out with these in the late 80's and discontinued them in the late 90's-2000 area due to lack of popularity and the fact that they aren't as easily tunable as the standard Holley carbs.
This is the same carb that Summit has very slightly revised and is selling under the Summit brand logo over the past few months as the Summit Carb. The Summit carb is supposed to have most of the tuning deficiencies of the earlier Holley design corrected, and most of the Summit tuning parts should fit the Holley, as it was directly based off the Holley.
Old 09-08-2009, 05:13 PM
woodz428's Avatar
Troll Hunter
I really liked those carbs, they are pretty much an update of the 60s era Autolite 4bbl. They ,however, have the cfm that was not available in the Autolite. They are probably an excellent street carb, their bowl gasket is at the top so less chance for a leaky bowl gasket, but as mentioned the aren't as "quick" to tune as a typical Holley. I do think they are as "easy" as far as determining and accessing the parts...they just don't open as easily.
Old 09-08-2009, 07:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I got one given to me by a Pontiac 400 guy. Tried it on my 455 Pontiac. It did OK, but to tune the accelerator pump shooter requires replacement of the "cluster", not a cheap proposition.
It also had the bad habit of percolating the fuel easily. The first run at the track would always be iffy due to heat soaking the carb.
I ended up using a wooden spacer under it.
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 03:01 PM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 04:25 PM
Holley Carb Question GoneNova/406 Engine 4 06-08-2005 07:09 PM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 02:47 AM
Need some pointers on Holley carb crshrmn3 Engine 2 02-09-2003 12:22 AM
