Later Fords started using a flange that the rear u-joint assy. bolted to if it has a trigger ring around it it's for ABS, if it's for leaves it is most likely the Versailles and if it's coils it is the wide big Lincoln. The Versailles is the same width as the early ('641/2-'66)'stang and works great in rods and many other cars (gives room for fatter meats in the '67-'70 stang. It is unlikely that it is 31 spline, and with out the tag how do you know it's a posi, if you can turn it to find that out then you can count the gear ratio as well.
Tom.... The information that you provided actually gave no indication of what information you were looking for. It was like calling your doctor and saying, "I'm sick, What's wrong with me?". The information from the other posts seemed to be very helpfull, or, I'm sure were meant to be. The people on this site try very hard to help, when they can. You will find some very knowledgeable people here. All you have to do is provide information and ask questions properly. If that is too much for you, then, GOOD BYE.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
