Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another Kobalt compressor ?
Old 08-11-2011, 08:50 PM
pepi's Avatar
pepi pepi is offline
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Sure I would think you could go to the next size just fine, would not suggest a bolt it might go to deep and interfere with something. You would be better off using a pipe plug. It just needs to be snugged enough to prevent an oil leak the next time you try, I say that cause you will not get to many chances to keep bumping up the size of the drain...
