Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Another manual disc/drum ??
Old 07-21-2009, 06:24 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
I am using 72 Chevelle discs/rotors/spindles/booster
67 Disc brake master cylinder
67 brake line set
All on a 66 Elky
Virtually everything is available from the auto parts stores
You will need to acquire a set of spindles for a disc brake car, along with the caliper mounts.
If creative, the spindles from drum car can be used with some grinding/cutting on the upper shield/caliper bracket mounting boss.
Your current steering knuckles can be reused.
Spindles and caliper mounts and shields are now being reproduced, but I do not know what kind of quality they are.
On my 59, I bought a kit----had trouble aligning the car when done
(2" drop spindles), and the tiny booster does not provide enough assist.
I have to use a 7" booster for valve cover and clutch master clearance
