Another Opinion on IFS Mustang II - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2010, 01:42 PM
I am building a 53 chevy 3100 truck. I want to put it on air bags. I need some opinions on which setup you like and why. I have been reading different posts about this, and thought I would stir it up again. I have looked at scotts, no limit engineering, tci, jim wiemer and hiedts. These seem like some of the better ones.
What would you recommend?
Aaron
Old 06-10-2010, 01:12 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Scott Danforth a member over on over on Stovebolt.com has developed a weld in cross member that keeps the front tires basically at stock width, using GM Metric A-arms and components('78-'88 El Camino, Malibu, Cutlass, Monte Carlo, S-10, Camaro etc.) and you can combine it with a couple of different rack set ups for the steering. Also a member over on HAMB (Junkbike) has Dan Scott's front suspension install on his AD truck w/airbags, looks great & it lays the truck down nicely. The rear of the front fender is about 2.5 inches off the ground with stock spindles..joe
Old 06-10-2010, 09:08 AM
slow4dr's Avatar
You're not going to find many differences between those manfucaturers when comparing Mustang II front ends. They are all based on the same basic geometry and design premis. Go with reputation first, customer service 2nd, as many american made parts 3rd, and price last.
I am a big fan of the double convoluted bags on a Mustang II. They have a bunch of travel and can easily lay the crossmember on the ground. Just make sure to c-notch the frame for tie rod clearance(most of the kits above include them).
-J
Mustang II IFS Install in 57 Chevy Truck mestes Suspension - Brakes - Steering 7 01-24-2012 08:12 AM
Rod&Customs Mustang II IFS question Caddy227 Suspension - Brakes - Steering 7 10-20-2008 09:29 AM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 08:15 PM
Mustang II IFS Steering Adjustment horvath Suspension - Brakes - Steering 14 05-08-2004 11:25 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
