another question about a 305 crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2008, 12:34 PM
Casperdude898's Avatar
is the unbalance of a 305 crank being in a 350 motor gna hurt performance that much?
Old 03-17-2008, 04:06 PM
If GM thought that it was necessary to have different crankshafts for them, I would imagine that there is something to consider! Might not hurt performance per se(pronounced per say), but longevity will definately be a concern. I have seen the bobweights between the two engines on stock applications be far enough apart in terms of total weight, that it would have most likely been very noticeable not to have balanced them for use in a 305 in a 350 and vice versa. I would rebalance if I had any doubts....
strocked 305 400 crank ideas???? ace29816 Engine 10 01-04-2008 06:26 PM
1987 Camaro 305 crank rebuild... what do I do and go with? ViperMonster800 Engine 4 09-14-2006 09:06 PM
305 crank in a 350 block 455c-10 Engine 5 05-17-2005 10:55 AM
1 more keyway n crank question? HemmiGremmie Engine 1 10-28-2004 11:33 AM
350 crank question stfinney Engine 4 12-03-2002 02:25 PM
