Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Another question about Black Paint.
Old 01-10-2011, 08:24 AM
cjperotti cjperotti is offline
Originally Posted by shine
ss urethane is preferred by many over bc/cc. simply because of appearance. in time the clear coat will get fine scratches in it which will give the car a cloudy look. light bouncing off the black under the clear. this does not show as much in ss . cutting and buffing is no different . both will give you the same quality .
depth is achieved by the clarity of the finish. not paint type or # of coats .
pigment has nothing to do with uv protection.
Everything shine posted except the last sentence I accept.
Urethane clearcoat offers little UV protection. Generally when a manufacturer informs you a clear has UV protection it will have added a UV tint to it and they caution the tint will affect colors such as white and yellows by shading them with a slightly brownish look in their tech sheets. Sikkens is notorious for this effect and requires that every paint job unless a complete paint job is to be performed to blend all work.
