Another Question for the blower guys - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2011, 05:52 PM
383Eliminator's Avatar
I think I have a small bore 6-71 which would explain my low boost. I pulled the carbs and plate off the blower today and took pictures. With limited information on the internet about the differences between small and large bore 6-71's. I measured the case thickness and it was just over an inch. If this is a small bore blower then the mystery is over, if not then im back to the drawing board.
ID:	58394   Click image for larger version
Old 09-14-2011, 06:07 PM
techinspector1's Avatar
Wiki Edits: 326
From Blower Drive Service' website....
"There are two different 671 blowers commonly used. They are the larger diameter blower and the small diameter blower. The large bore blower (case thickness 1/2"-) is approximately 11 percent larger in volume than the small bore. The small bore blower (case thickness 3/4"+) is recommended for 370 CID engines or less for street applications. The larger bore blower is recommended for 371-500 CID engines in high performance, racing applications."
How many square inches of filter area do you have for the carbs to breathe through? I would want at least a 4" x 14" element. If the motor can't breathe, it can't make boost.
Old 09-14-2011, 06:14 PM
Thanks alot tech inspector. Thats about all the information I could find. I also called BDS and they said a Weiand could be either one. If I did my measurements correctly then I definetly have a small bore blower. Just wanted a second opinion.
Old 09-14-2011, 06:42 PM
Wiki Edits: 326
If it's a Weiand, then it's not a 6-71. It's a Roots type blower, but not a 6-71. Weiand rates their blowers by the amount of air displaced for a complete rotor turn. GMC rated their blowers by the number of cylinders and the displacement per cylinder.
Old 09-14-2011, 08:16 PM
by the measurement you gave and the length of case for the rotors is 15" you have a small bore . just spin it a little faster
Old 09-14-2011, 09:05 PM
Thanks a lot 1932 bantam. I thought it was a small bore but people usually look at me like I'm crazy when I say small bore and large bore 6-71. Anyway I will pick up another pulley and try to get a couple more lbs of boost. Thanks agian..
Blower guys chime in NOlowrider Engine 2 08-09-2010 07:02 PM
Hey guys. Blower for LS1? Need height estimate. Stovebolter Engine 0 06-12-2008 10:46 PM
Blower guys. Help! HemmiGremmie Engine 16 11-23-2005 06:16 PM
one more for the blower guys minesblown Engine 4 10-22-2003 07:32 PM
quench question for the blower guys minesblown Engine 7 10-16-2003 12:49 AM
