Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another sbc question
Old 10-30-2012, 09:47 AM
wildeman wildeman is offline
ProStreet620
vinniekq2, the motor is fine but it was advertised as 400hp. With the heads that are on it, I'm guessing around 370 hp, which makes me feel kind of ripped off. What other cam specs do you need? I listed everything except LSA and centerline. LSA is 109 and centerline is 107. This is going into a 76 Datsun truck that I hope tips the scales at less than 2500lbs. and will run somewhere in the 12s because this is actually a mild motor.
