Another Spark plug ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2014, 09:31 PM
I am seeing the timing is correct. The heat range a little cold, (r43ts). Jetting is FAT.
BUT, WTH is up with the porcelain?
Engine has 2400 miles since rebuilt, spark plugs have 2400 miles on them also.
I will try to get better lighting.
Old 06-03-2014, 09:34 PM
Old 06-03-2014, 10:35 PM
forgot to add.
mid 80's 350 chevy
87 octane , i believe with ethanol added
Carburetor
Old 06-04-2014, 06:15 AM
Originally Posted by jjforgin234 View Post
I was told to never tighten to plugs once inside the engine, so I didn't.
What does this mean?
Old 06-04-2014, 06:23 AM
poncho62's Avatar
Wiki Edits: 5
Disregard...He was a spammer .......
Old 06-04-2014, 10:01 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Those plugs don't look like it's jetted fat, also looks like possibly some aluminum on the ground, has it been detonating? What's your timing at?
Semper Fi
Old 06-04-2014, 11:24 AM
Wow as stated previously....looks like pre-ignition and or detonation. Seem like flame front is starting somewhere else and whacking the porcelain on one side and burning it. something not good is going on. Maybe mixture is too lean or engine is running too hot. Could the catalytic converter be plugged up?
My grandfather would say you've got carbon buildup. His treatment would be to race the engine hot and slowly pour quart of water down the intake to "blow out the carbon" Dangerous....Those old timers crack me up.
Old 06-04-2014, 12:25 PM
techinspector1's Avatar
Wiki Edits: 326
Those black specks on the porcelain could be oil that was jetted out from the top ring land due to detonation. First you get black specks from oil, then you get silver specks from the piston. Looks like the pistons are disassembling themselves. Cylinder pressure is to high for the fuel being used.
Old 06-05-2014, 08:12 PM
Dang , this thing seems its going from one extreme to the other. Not looking good either way. What could be causing this , bad rebuild?
These plugs have 200 miles on them with a couple full throttle runs. The plugs are R45TS what the low compression truck crate engine calls for. Its a Goodwrench crate with stock cam but has been rebuilt with cheap parts by a rebuilder company.
Timing is 36@3000RPM with egr and 16 of vacuum advance
8.5:1 compression ratio. I am sure its a little less with cheap piston on rebuild.
250 HP @4300 rpm
350 ft. lbs of torque @ 3600 rpm
It looks like the full throttle runs brought the problem out a little more to light. Looks like what i am thinking was jets being fat is actually oil. Engine has 2500 miles on rebuild, should I keep driving see if the problems clear up? Engine seems to run very smooth for the most parts and every once in a while it will miss at idle. Then other times at idle its perfectly smooth.
Old 06-05-2014, 08:13 PM
Old 06-05-2014, 10:04 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Looks like oil being pulled through the intake valve guide. Does it use oil or smoke at start up? Have you leakdown tested it?
Today's gasoline makes plug reading even harder than it was 30 years ago when it was an art to begin with. There is too much added stuff for emission compliance and the ethanol will clean much of the traces anyway. It's good your remaining active, but do keep in mind the accuracy is suspect.
The Following User Says Thank You to johnsongrass1 For This Useful Post:
techinspector1 (06-05-2014)
Old 06-05-2014, 10:42 PM
There is a VERY SLIGHT puff of smoke at start up , unnoticeable if your not looking at it.
Haven't leak down tested. will do a compression test this weekend.
Old 06-10-2014, 06:47 PM
Cars, Trucks, Boats
. Maybe vacuum pulling in oil at intake to head gasket, past rocker studs threads* if screwin type with guide plates, or past valve guides... is it happening to all 8 plugs or just some of them?
. *sometimes bottoms of some rocker stud holes break into intake ports...
89 5.0 H.O. spark plug wireing/spark order psikpa Modern Electronic Engines 6 05-11-2012 09:01 PM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 06:14 AM
Spark plug help dar130 Engine 1 01-25-2008 11:25 PM
A new spark plug again dawg Engine 8 12-28-2007 02:47 PM
Spark Plug Help! fordf_1502004 Engine 4 12-07-2007 04:40 PM
