Another strange electrical connector - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2008, 02:39 PM
cboy's Avatar
Last journal entry: Finished
A couple months ago there was a thread regarding a very strange looking household outlet. Last week I plucked this blower from a Jenn-Air range my sister was discarding hoping I might be able to use it to exhaust my blasting cabinet. (I don't know the cfm but it looks pretty stout to me.)
When I went to test it out the plug just wouldn't go in the wall outlet no matter how hard I tried to jamb it. Finally I took a look at the prongs and was quite surprised (see pictures below).
I'm assuming this is some sort of proprietary thing Jenn-Air does to try to make you buy THEIR blower when you need a replacement. Anybody have a better idea? I'm just going to hack off the plug and replace it with a normal one - unless somebody knows a compelling reason not to.
Always learning...and sharing what I've learned.
Old 05-08-2008, 03:10 PM
31 five window
Last journal entry: grill and rear end
I am with you,Go for it.
Old 05-08-2008, 03:58 PM
Last journal entry: Journal Update
Strange Connector.
Just lop it off. Chances are it's either a 120v or a 220v motor. Down side of a 220 motor is it will run at 1/2 the speed. Just the companies way of making sure you are not going to use it for something else.
Old 05-08-2008, 05:15 PM
ortamenxs's Avatar
Avoid the Gremlins.
I had a motor off an industrial vacuum that looked just like that, I just replaced the plug head on mine by splicing a old shop fan end on. (I used the rotating shaft to make grinder, and ran the blower to blow the dust/shavings away from my face.)
Old 05-08-2008, 06:07 PM
cboy's Avatar
Yup. I just lopped off that funny lookin' plug and put on a normal plug and it runs great. I still have to get the input side of the squirrel cage adapted over to my blasting cabinet but I think the setup is going to work much better than the shop-vac set up I currently use. This puppy really moves a lot of air. Best part is...it was FREE.
Old 05-08-2008, 08:17 PM
I would have just smashed the plug peg.
Shane
brake combo valve electrical connector dawg Suspension - Brakes - Steering 9 01-21-2007 07:39 PM
GM electrical connector zipfactor Electrical 8 08-12-2006 10:51 AM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 08:27 PM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 07:41 PM
700r4 Electrical connector arch Transmission - Rearend 5 06-22-2004 05:49 PM
