another TDC question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-06-2008, 06:09 PM
Originally Posted by Jmark
No problem.
When I did mine and my sons, I used a dial indicator but ran it "in the hole" some. Came "up" and brought it till it touched, then past and "down" till I came to the same reading, divided on the wheel and got it nailed down. Cked the cam and mine was exactally on and my son's was 1.5 degrees off. Close enough.
OK, that way IS accurate, locating TDC by measuring either side of TDC and spliting the difference works the same whether useing positive stop or dial indicator will yield the same result. i thought when dial indicator was mentioned someone would be trying to find TDC by looking for the highest reading to find TDC.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
