another timing problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2010, 08:15 AM
my 1984 csb 350 idles fine good throttle response while in park but if u put it in reverse it lugs and if u put a timing light on it it show the timing mark straight up with the block could this be because of a timing chain being changed incorrectly? yesterday changed the vacumn advanced this helped a little changed carbs ran worse ruined a set of brand new spark plugs in a total of maybe 12 minutes ideling i do believe that the spark plugs were ruined do to diesel and water still in the tank
Old 09-26-2010, 08:58 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I little more info would help. So if I am reading this right the timing chain was replaced and now the engine runs bad?
It is possible that the cam and crank sprockets were not lined up with the #1 piston at true TDC, this would through out the engine timing to start with. Was TDC verified during this chain replacement? Also was the timing pointer position lined up correctly with the balancer 0 mark. What do you mean the timing mark is straight up? what is the base timing on this motor? 8,10,12,14 BTDC?
Post some more info on the motor ie:
Is this a stock 350 with factory cam, heads and block?
What type of carb
What type of distributor
How many miles on it
Diesel in the tank?
Old 09-26-2010, 09:09 AM
stock 350 except headers
quadrajet carb dont know the cfm
recently made a diesel conversion out of this blazer (took the 6.2l out and put the 350 in it) i drained the tank the best i could and i gues there was a little rotten diesel still in the tank. hei distributor yes the motor was tdc when we changed the timing chain
Old 09-26-2010, 09:12 AM
oh and when i say the timing mark is straight up i mean its pointing towards the water pump roughly 20 degrees advanced 864202468 is my timing marks i beleive
Found problem with cloyes timing cover. eric32 Engine 3 07-23-2009 06:21 PM
388 stroker timing problem 71nova1 Engine 22 03-16-2009 07:32 PM
timing problem? crush56 Engine 21 10-28-2005 10:42 AM
455 timing problem msc66 Engine 2 05-02-2005 08:41 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
