Another Value Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2013, 09:40 AM
46highboypu's Avatar
Last journal entry: More pin stripes
Having seen such questions posted here my son has asked that see if anyone would care to offer suggestions on priceing some of the stuff he has in the woods (What a Score post). He thinks the 39? Plymouth sedan and the 40 Nash coupe would be desirable but what are they worth? I know that's relative to what ever but any idea? Another question about the artillery style wheels is, are they worth more as is or would it be better to blast and prime them? We are open to ideas.
ID:	70924   Click image for larger version
ID:	70925   Click image for larger version
Old 01-29-2013, 10:07 AM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
As for the value of the cars, its almost impossable to put a price on anything by only seeing a picture, some up close detailed pictures, of the extent of the rust areas, fenders , interior, ETC, might give a interested party a little insight,,,but even then ,anyone interested would be nuts to buy anything there ,, sight un seen,,
as for the wheels,,, I think if they were blasted and primered, and made presentable,, would be a huge improvement over some rusty dirty wheels,,, Artillery wheels are hard to find,, spend a little time and elbow grease to make them more presentable,,
Old 01-29-2013, 11:10 AM
I can't imagine the cars are worth very much, they look very rough. On the wheels I believe those are 36-39 large bolt pattern and I don't believe they are worth much.
Old 01-29-2013, 11:40 AM
Bad Rat's Avatar
Wiki Edits: 2
how can you tell the year , when the bolt pattern isn't visable in the picture' whats the visual differance in these and the earlier wheels,
I'm not any kind of authority on wheels,, I was just wondering how you can determine that they are the large bolt pattern, when you can't see the bolt pattern?,, is there a differance in the spoke pattern from the earlier of Later wheels,, like I said I don't know the differance,,,,
Old 01-29-2013, 02:28 PM
Because it has the large cap. I know these caps doen't look exactly like the ones pictured I believe they are aftermarket. But you can see the size of the cap is identical to the painted portion around the stainless center on the wheels he posted. That part comes off with the cap I do believe.
Here is a 39 that looks almost identical outside of the stainless cap.
Before that I don't even think they had that style wheel did they? They were all wire, unless it had the accessory "jumbos" or something. That is what I remember and a quick Google didn't get me anything but the wires so I believe those wheels to be 36-39 but I sure as heck could be wrong.
Old 01-29-2013, 02:35 PM
Here you go, they are 1937.
The Following User Says Thank You to MARTINSR For This Useful Post:
Bad Rat (01-29-2013)
Old 01-29-2013, 11:15 PM
Bad Rat's Avatar
Wiki Edits: 2
Oh Ok!! Now I see what you are talking about, , Thanks Brian,, learn something every day, well maybe not EVERY DAY,, remembering it is my problem now
we did a 36 chev for a client, but it was cheapie model,, and it had the 16" regular steel wheels not the artillary, still have them,, UGH!!
Old 01-30-2013, 07:45 AM
The 36 Chevy never had that giant bolt pattern the 36-39 Ford did. Chevy used the same bolt pattern as now I believe all the way back to the spindle mount,, I think ??. The only other car I know of that that it ever was the VW which used a 36 and a 38 Ford that was brought back to Germany to dissect!
1936-39 Ford wheel.
Old 01-30-2013, 10:20 AM
Bad Rat's Avatar
Wiki Edits: 2
that does look like a V/W wheel,,, now I see the reason for the huge hub cap
Old 01-30-2013, 12:13 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
VW and Posche used these type wheels 66 and older ,we got a 37 olds in shop it uses 5 on 5 bolt pattern like a chevy pu ,chevy may or maynot be the same as Olds.
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 05:02 PM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 07:38 AM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
