Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another vortec question
Old 11-14-2012, 10:14 AM
engineczar's Avatar
engineczar engineczar is offline
There are also several options depending on what type cam you're running. What style cam do you have? Solid, hyd, roller. What spring are you trying to squeeze in and how much seat pressure do you need? Also what are the actual measured spring pressures at the two different heights 1.75 and 1.685. Often the springs measure out different than what is advertised.
BSE Racing Engines
The Following User Says Thank You to engineczar For This Useful Post:
oldworldnewtoys (11-14-2012)
