Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another vortec question
  #28 (permalink)
Old 11-15-2012, 03:38 PM
ap72 ap72 is offline
Banned
Originally Posted by MouseFink View Post
When I mean larger spring, I not only mean larger OD and height but I also include larger wire diameter.
In order to use a spring with a larger wire diameter, it must be a taller spring or compromise the coil bind or use a camshaft with less lift.
Lets go to dual springs then and keep the small wire diameter so not to compromise the coil bind height, Doggone it! You must have a larger diameter outer spring to accept the inner spring. Right?
First off, when you're dead wrong, no one can guess that you didn't really mean what you said, if that is the case then there is really no point in saying anything as its never what you meant.
Secondly a thicker wire diameter can be ran with a shorter spring or a smaller OD.
Lastly, with a different spring material you can run smaller diameter, and smaller OD and a shorter spring and still end up with more pressure and travel.
