Ansen scattershield/clutch lever - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2005, 11:42 AM
I picked up an old Ansen scattershield to use behind the 327 in my roadster, but found out the standard Chevy stamped steel throwout arm is too wide for the hole in the side of it. Anyone know what I should be using? I could open up the hole but would rather not. Thanks for your help.
Old 10-03-2005, 10:25 PM
As one of the Moderators here....I would like to.
WELCOME YOU HERE.....
I had the same throwout arm problem years ago ( Many years ago ) and I found one from a V8 Nova worked for me.....it was smaller......
DISCLAIMER. : : : I got mine from the junk yard and it might not have been a factory Nova part....but I do know Nova's had a smaller bellhousing and special clutch linkage and a special clutch ball placement on the V8 Nova blocks.
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 04:29 PM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 07:56 PM
Removing shift lever pin cboy Suspension - Brakes - Steering 4 02-23-2004 08:53 PM
Aluminum Powerglide shift lever. shaggy56 Transmission - Rearend 1 10-10-2003 12:02 AM
What is a kickdown lever for? kemo Transmission - Rearend 3 02-10-2003 09:44 PM
