Ansen Traction Bars. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 09:06 AM
Need some expertise guys. 57 Chevy Mini-Tubbed with Currie rearend. Has Spring Re-location kit. Purchased set of Ansen Traction Bars. Aft portion where U-Bolts go around Leaf springs & rearend mounts up perfect. Forward portion of Traction Bar bracket, has a small u-shaped clamp with a tab , Bushing & pivoting Bolt, that would normally mount on Leaf Spring. Due to re-location kit, the fwd part of Leaf Spring is hidden into car frame which makes Fwd portion of Bars unable to mount. Question is this: Would there be any damage to Rearend if I welded Fwd mMunting Brkt of traction bar to car frame? Just forward of the leaf spring? So basically the Rear portion would mount correctly & to rearend for movement, & Fwd portion would be Welded or Stationary without side, frd or aft play since it will be welded to frame? Is this possible to do & have no issues with rearend or would it damage something. Thanks
Old 04-22-2011, 03:53 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Can you still get those bars other then ebay or somewhere else ?
Cole
Old 04-23-2011, 12:17 PM
Traction Bars
Not sure if they are still avail. Lucked out at Car Swap meet. Some guy must not have known what he was selling. After cleaning the crud off them & having them Powder Coated they came back to life.
Old 04-23-2011, 12:20 PM
eloc431962's Avatar
Wiki Edits: 37
That was a very good find IMHO.
Cole
Traction bars? 383SBC Suspension - Brakes - Steering 1 03-11-2010 09:05 PM
lift bars and traction bars hause Suspension - Brakes - Steering 1 10-05-2006 01:50 PM
Latter Traction Bars th3 pla6u3 Suspension - Brakes - Steering 5 07-21-2006 10:37 PM
Traction Bars ChevelleGuy Suspension - Brakes - Steering 3 01-23-2006 11:00 AM
Traction Bars or Ladder bars JamesRS Transmission - Rearend 1 07-19-2005 05:57 PM
