antenna mast - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 09:28 PM
mitmaks's Avatar
Last journal entry: Grille
antenna mast
So my mom's car had bent telescoping antenna mast. I installed another one and it worked for a few days and later on broke. I took it apart to see what was the problem and the plastic belt thats inside of it tore out from antenna mast. It looks like end is arrow shaped where it will bite into mast and stay put. I guess motor is too powerful and tore it out. I was thinking how I could secure it inside so it wont come out again
Name:	MR282623 3000GT Antenna Mast.jpg
Old 04-05-2011, 09:54 PM
Maybe inject some epoxy into the end of the mast with a long syringe?
Brake booster and Mast. cyl que? 39chevy Suspension - Brakes - Steering 2 02-22-2010 12:35 PM
Antenna shaving blacksunshine Electrical 6 07-25-2006 02:19 PM
67 camaro antenna eastvandan Introduce Yourself 2 04-26-2006 06:49 PM
What mast. cyl. bore to use. murrsue Suspension - Brakes - Steering 9 12-28-2004 03:45 PM
frenching an antenna Lay'nFrame Body - Exterior 1 03-15-2003 08:49 PM
