Antenna shaving - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2006, 02:31 PM
blacksunshine's Avatar
Bleed Blue
Antenna shaving
Hey all, I have a failry simple question. Im finishing up the bodywork on my 69 torino and want a cleaner look by shaving off the extrememly long and odd looking antenna. This is the easy part. The question I have is, where can I hide / relocate the antenna so I can still use the factory AM radio, or an aftermarket FM unit and pick up stations. I dont want a cheesy install anywhere. Or is there an aftermarket unit I can put behind the grill etc.. to still pick up stations??
Old 07-24-2006, 02:36 PM
Bleed Blue
Actually I think I just answered my own question. Google. They make hidden antennas. http://www.casmfg.com/Accessories.htm
Any other ideas greatly accepted though.
Old 07-24-2006, 03:52 PM
Wiki Edits: 31
replace it with a power antenna and it will go away until you want tunes
Old 07-24-2006, 03:54 PM
Bleed Blue
I thought about that but, I really want it gone. Nothing at all sticking out of the fender...unless i frenched it.
Old 07-24-2006, 05:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Get a Windshield Antenna, and install it OR for a pro job, get a Windshield for your car with the antenna in it..Depending on how many $$ you want to spend..
Stealth antennas Can be a nightmare..depending on obstructions, mounting positions (most broadcast stations are vertically polarized signal..meaning antenna must be up/down for optimum reception.) AND where AM is involved, Just about anything can be a RFI producer..like anti rattle clips, rubbing suspension and the like. Remember, AM radio is nothing more than a SPARK , traveling through the air, with Audio information imposed on it...(that's why it is noisier than FM..)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-25-2006, 09:50 AM
Bleed Blue
Aaah...ok. Thanks Doc. See this helps a little. I was going to just hide the hidden antenna "box" from the link above just behind the grill. I mainly want the AM there for looks and originality..just because it's kinda cool with the 1 crappy speaker and all then I was going to hide an FM/CD player somewhere for the cars system and split the antenna for both radios.
Even the website says there is nothing better than a 31" mast antenna. And they say you get best performance from the top of windshield. I guess you have to sacrifice radio range, and clarity for looks... So windows antenna.
The one I looked at was the crutchfield one. http://www.crutchfield.com/S-Iu5Q76H...0&I=12044UA200 But really, who wants that in their interior up on their window?? A wire in the glass would ideal, but I dont know if I have the money for that kind of custom work. I wonder if the "box" looking hidden one would work well behind the upper part of my rear window. It is a fairly flat window.
Old 07-25-2006, 02:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That one will work....HOWEVER...
The one I was referring to, is the Kit, for the tiny black wire that installs on the glass..(like late model GM' antennas and heaters..)
There is a kit for that kind of antenna, that requires it be attached to the glass Via the adhesive they provide, Then, when Dry, you peel the sticky back off the wire ... All that remains is a tiny black wire that goes around the edges of the windshield..
At the right bottom edge, is an edge card connector, with your Coax Pigtail leading from it..
Check with a GOOD auto stereo shop, OR auto glass installer OR , local speed shop for the kit..
Your Glass MUST be spotless for it to work (stick) and The edge card MUST be epoxy attached so as it will not pull the antenna wire from it.
Doc
Innovations
shaving lowcivic Body - Exterior 1 05-08-2006 12:41 PM
Hidden antenna BigMac Electrical 10 11-11-2003 05:34 PM
How does french antenna work? ChrisMiddleron Body - Exterior 3 06-21-2003 11:24 PM
motorized radio antenna 63 vette Electrical 8 03-22-2003 07:20 PM
Hidden Electronic Antenna Dave E Shank Electrical 1 08-15-2002 09:18 PM
