Anti clunk spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2008, 04:03 PM
Anti clunk spring
Hi all,
Can anyone help me locate an "anti clunk spring" replacement block. The case in my turbo 350 trans is almost worn through where the low/reverse roller clutch and the anti clunk spring come toghether. There is supposed to be ablock that is used in place of the spring and will alow you to use the case again. I've searched everywhere with no success! Thanks!
Joe
Old 02-03-2008, 06:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by BJV269SS
Hi all,
Joe
the problem with the 'block' piece you describe is under a high load situation the center support can split since only one spot is holding the power.
NATPRO lists these repair items you are looking for in their catalog....
1 piece is #GM-1026
4 piece kit is GM-1025
The 4 piece is a better design, IF it is still available.
A better solution is the center support that has been machined for a plate that bolts onto the center support and lugs into ALL the non worn area of the case lugs in the trans case.
Old 02-03-2008, 10:33 PM
Is there some attachment that you have to this particular case? I see th350s in the classifieds for around $200 occasionally.
Shane
Old 02-04-2008, 04:08 PM
Anti clunk spring
Hey Crosley!
Thanks for the reply! I see where your going with the block under high load. In a stock situation would it be a user? I like the set-up that has been machined for a plate that bolts onto the center support and lugs into ALL the non worn area of the case lugs in the trans case. What would I be using, the used steel plates machined to fit? No kits like that? Sounds like the machining might be expensive. New case better $ wise?
Joe
Old 02-04-2008, 04:35 PM
Crosley did I get to the right place? NATPRONET.Com I could not find a catalog to look at or down load. Do ya have a web site for them?
Old 02-04-2008, 06:24 PM
Jmark's Avatar
I could not find online parts at Natpro either.
I did find a 4 piece kit online. click here.
I know and have seen the "good" one that Crosley mentions. Transtar sells it. I"m still trying to find it.
Mark
Old 02-04-2008, 06:32 PM
Thanks for all your effort!!!!!
Old 02-04-2008, 06:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the plate design that bolts to the center support kit is sold my Hughes Performance of AZ
Old 02-04-2008, 06:38 PM
Jmark's Avatar
Originally Posted by Crosley
the plate design that bolts to the center support kit is sold by Hughes Performance of AZ
Tony, does Transtar sell it too? I've seen the guys at Aamco install the one you mention and they use Transtar. Very good part.
Old 02-04-2008, 06:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I do not know... we have the plates water jet cut, coated, the center supports machined... all in the USA.
Old 02-04-2008, 07:04 PM
What is this plate called? I can't find it...still find it! They still have the blocks. Under $2.00
Old 02-04-2008, 07:51 PM
Jmark's Avatar
I've found mention of it online, but have not found a picture or a place that sells them. They referred to them as a "center support case saver".
Give Transtar a call tomorrow. They have warehouses in different states. I just caught a glimps of the one I saw them use. It was similar looking to the center support and bolted onto a modified support plate. (I think! LOL)
Mark
Transtar industries
AH...Haaaaa!!! I found one! LOL Second picture down. 65 bucks. It's a "thin center support" that has been drilled and tapped and then another like piece is bolted on.
Center support case saver.
Old 02-05-2008, 05:06 AM
Hey Mark!! THANKS SO MUCH!!!!
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 11:16 AM
Leaf spring mounting question flynbrian48 Suspension - Brakes - Steering 2 01-22-2008 11:30 AM
Did I install my Anti clunk spring and Overrun Band right? (T-350) Warrant Transmission - Rearend 7 06-06-2006 07:42 PM
Any one ever have this spring problem iceman36 Suspension - Brakes - Steering 6 03-03-2006 07:20 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 09:24 PM
