Anti-Dive on MII front suspension with Air Bags - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2013, 11:10 PM
27TRoadsterguy's Avatar
Last journal entry: Frame Basics
How do I set up an MII front suspension which I want to equip with
Air Bags. From what I've seen it cannot be done by angling the top
spring towers that 4 degrees. The air bags will not tolerate it, or will
they? The project has come to a halt till I figure this out.
Thanks in advance
Carl
Old 07-21-2013, 10:42 AM
Thanks in advance
Carl
You can use a Shockwave type bag to do it, or you can set the bag mount at 90 degrees, while angling the upper arm 4 degrees as normal.
Old 07-21-2013, 12:05 PM
kso's Avatar
kso kso is offline
Maybe you could cut a rectangular portion out of the front a-arm slot and weld in a raised cup with the slot in it again. Of course the whole upper mount would need to be lowered half of what ever amount (1/2"?) you raised the one slot to adjust for it.
Adding front bags to '95 air ride system Mutt's37Buick Suspension - Brakes - Steering 0 03-09-2012 11:11 AM
Anti dive angle.... Rickrak77 Suspension - Brakes - Steering 2 12-01-2006 06:44 AM
Front Air Bags and Leaf Springs BillVV Suspension - Brakes - Steering 1 06-16-2006 08:07 PM
RRS Front Suspension Geometry: No Anti-dive? Brian S Suspension - Brakes - Steering 9 10-12-2005 03:45 AM
69 Camaro Air Suspension (bags?) Front G_Ecker Suspension - Brakes - Steering 2 12-24-2003 03:50 PM
