Sorry I havent ever installed a pair. Most of the stuff i work on is to old, to new, or just cruisers. where they never really get on them. However i would suspect that ther should be some tech info out there or installation instructions with them. The last time i bought leaf springs there were instructions with them, go figure.
\ Tom |
If you buy new ones there should be complete instructions with them. If you buy name brand used ones you should be able to download complete instructions online. That's what I did with a pair I bought.
Hey Juiced
If the no hop bars your thinking of are the ones that go from the center of the rearend housing up to the upper trailing arms , I don't think they will work with a 9 inch Ford rearend because part of the no hop bars bolt into a hole that you drill into the webing that is cast into the center section of a 10 and 12 bolt Chevelle rearend and a 9 inch Ford third member dosn't have the webing in the same place. Gene |
Hey Trail,
Motor is a 383, trans is a rebuilt beefed up 350 TH hooked up to a Gear Venor, Vigilant 3000 stall converter (wish I bought the 3,600 converter and 4.11 rear gears. I am really disappointed in the traction (2.1 - 2.3 60 ft.). One thing that I am pleased with is my upgrade to a Lokar Cable set-up for my throttle linkage. My stock throttle assembly was very shaky and was not opening to WOT with hardly no top end. I plan to take it the track and I hope to break into the 11's. That's why I am looking in improving my traction. I'll also look into coilover shocks (QA1). I am soooo close 12.5. As noted by 57half ton, I'll contact Edlebrock's or Summit's tech department if my set-up can be adapted to accept the anti-hop bars. |
Trailing arms
How do you get a 72 Chevy c10 with trailing arms to hook up....
you don't need the bars, your 9" raised the upper mount points, and thats what the hop bars do.. when used on a 10 or 12 bolt.. I'd invest in adjustable upper arms(links) |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| wheel hop whoas | ElCa/monty | Suspension - Brakes - Steering | 6 | 05-19-2007 10:16 PM |
| Traction Bars or Ladder bars | JamesRS | Transmission - Rearend | 1 | 07-19-2005 05:57 PM |
| 2nd Gens... How do you stop the Hop? | 98 SNAKE EATER | Suspension - Brakes - Steering | 13 | 01-03-2004 12:18 AM |
| traction bars | corenele | Suspension - Brakes - Steering | 8 | 06-14-2003 01:37 PM |
