Anti-Sieze on cutting burrs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2011, 03:24 PM
A few months back the question came up about clogging burrs when used on aluminum. Someone suggested using anti-sieze compound, well I just had some aluminum come in and had to do quite a bit of grinding on and recalled the suggestion, tried it and was very surprised how well this works.
What useually takes an hour was cut down to fifteen minutes.
Thanks to whoever it was.
Old 08-31-2011, 03:59 AM
Transmission fluid works also and is less expensive.
Old 08-31-2011, 09:52 AM
I used WD-40, and just keep grinding. This was on some VW heads, for a sand rail.
Oil pump sieze fourby2 Engine 2 06-12-2009 05:27 AM
Crank Timing Gear - Anti-sieze?? dhunt00c Engine 11 05-24-2008 06:51 PM
Anti-Hot Rods kilchsgray Hotrodders' Lounge 48 10-09-2006 02:26 PM
carbide burrs volkswagentuned Garage - Tools 12 10-14-2005 02:11 PM
Anti-Piggy Kit? 6thjoker Electrical 12 01-27-2003 10:47 AM
