Anti Sway Bar 28 thru 31 MII - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2008, 07:10 PM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
I have a 29 Ford Sedan with a Mustang II front end. I would like to add a anti sway bar to eliminate some of the dipping I get going around corners. But there is no room for a standard Mustang II bar to fit as the frame does not extend that far forward of the A frames to attach it. When I put the bar somewhat in place th e bar extends pass the front of the bumper. I figured some one must have done this or at least had a solution. Any ideas?
Old 05-21-2008, 11:45 PM
jalopy45's Avatar
Sounds like you need a better spring and shock set-up, but if you still feel the need for a sway bar try using one at the rear of the car.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 05-22-2008, 02:42 AM
staleg's Avatar
Last journal entry: Hand brake
Is it room for it on the back of the suspension?
Old 05-22-2008, 06:47 AM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
I have been working on that, in fact the shocks are new and have about a 1000 miles on them. The coils are the 3rd set I have installed. The first gave to much give and on a lot of corners the turning tire hit the fender. Also they gave a clearance height of 3 1/4 inches, which turned out to be too low. The second pair was a little too stiff. Generally this third pair pair gives a good ride, but I did hit a hole and was making a turn at the same time and it did hit the fender. Of course I am still trying to keep it as low as possible. It seemed to roll more in the front,but that could maybe because I sit up front. If you think about it the frame is a stout one so if there is any torsional twist it would be very slight. I was wondering if I could mount it behind the A frames, so the rear is another option I did not think about.
Old 05-22-2008, 06:55 AM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
Again that is a good question. It seemed to roll more in the front,but that could maybe because I sit up front. If you think about it the frame is a stout one so if there is any torsional twist it would be very slight. I was wondering if I could mount it behind the A frames, so the rear is another option I did not think about. To be truthful here, I did not think of the front sway bar idea to begin with. I have a mechanic (new Chrysler)/race car driver (modifies & drags) suggested it. I was in left field with my idea.
Old 05-22-2008, 03:55 PM
staleg's Avatar
Sorry for my bad english. What I ment was is it room for the front sway bar at the rear of the front crossmember?
Old 05-22-2008, 04:04 PM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
Sorry for my bad English. What I meant was is it room for the front sway bar at the rear of the front cross member?
I won't know that answer till I get the car on the lift. Your English is much better than my second language (Spanish).
Old 05-22-2008, 08:54 PM
jalopy45's Avatar
I used a MII (Fatman Fabrication) front crossmember in my '45 Ford Pickup, worked great without a sway-bar until I started towing a trailer, then I installed one on the rear and all problems disappeared.
Old 05-23-2008, 01:09 AM
staleg's Avatar
I will try to adapt a sway bar in that position to my '34 roadster's Fatman M II suspension too.
I have found one app 7/8" from a Nissan pick up that looks like it will fit pretty well.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 09:33 AM
problem installing front sway bar 40 ford. EGOP8 Introduce Yourself 3 03-25-2007 09:05 AM
Sway Bar bushing blues bowtyebob Suspension - Brakes - Steering 6 11-27-2006 06:58 AM
New Anti Sway Bar for 1939 Pontiac rwruther Suspension - Brakes - Steering 2 06-26-2006 12:01 PM
65 Belair Sway bar question sabino56 Suspension - Brakes - Steering 11 12-26-2005 09:22 PM
