Originally Posted by srob67
I just rebuilt my sbc 406 and upon the first start up it would not fire. I tried several times to get it to start but it wouldn't. After a while I noticed that antifreeze was coming out of the passenger side header. I stopped and started tearing it down hoping for just a pinched head gasket. Found I have a cracked head. There was antifreeze sitting in the cylinders on that side and also in the oil. How do I clean all this up and how far do I need to tear this thing down?
You have positively found a cracked head? A cracked head can put coolant into two cylinders that sit side by side but you usually don't see more than two cylinders w/coolant in them from a cracked head- unless it's well and truly CRACKED!
So if it's for sure a cracked head, blot out the coolant w/paper towels (don't get lint into everything), be sure there's no coolant in the oil pan. Drain it to be sure, if nothing is in the oil, reuse it as long as you keep it clean.
You
could reuse the head gasket, but if you want to be safe, replace it. Be sure the torque sequence is followed and that you tighten the head fasteners in at least three steps to 65 ft/lbs or whatever the fastener manufacturer recommends if different from that.
Also be sure the intake gaskets are sealing around the water crossover and the intake ports so there's no coolant or vacuum leakage there. Same thing on replacing them as well as following the torque sequence.
You are using break in quantities of ZDDP in the motor oil, right?
Some info that may help:
Firing order
HEI distributor info
Adjusting the valves
Head gaskets
Cam installation
Valve train points to check
Differences in SBC timing tabs and damper TDC lines
