Antifreeze spill - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 10:16 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Antifreeze spill
Hi ...I'm still having problems with seeing a little antifreeze under motor once in a while. It seems to happen about once a month. The motor never over heats. I have never actually seen where the water comes from but its in the area of the radiator expansion tank. There is no thermostat so its not that.
Question.....Does the radiator expansion tank have to be at a certain level in relationship to the radiator cap? And how far away from the radiator can the tank be?
My ride is a 36 Ford w/350 Chevy motor
Thanks
Bob
Old 07-06-2012, 10:54 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Thanks
Bob
Hi Bob, just which type tank did you go with a overflow type or and actual expansion tank ? on a overflow it don't really matter higher or lower JMO, But i alway's mout mine lowewr on a overflow style tank. and i really don't think it would matter on a expansion style tank either because when it heats up it will push into the tank either way. JMO. If you went with the overflow style tank did you set it up to re-circulate back into the radiator ? there are usually to way's to go with the overflow style tank it would be vented at the to with the overflow hose hooked into the bottom of the can, or un-vented with the hose and a pitcock in the bottom of the can which every so often you would have to drain as it will fill up and have no where to go. Hope all this help Bob.
Cole
Old 07-06-2012, 10:56 AM
eloc431962's Avatar
Wiki Edits: 37
And also Bob you might want to go ahead and put a pressure tester on it to see/ look around for any leak. IMHO
Cole
Old 07-06-2012, 12:13 PM
Bobs36ford's Avatar
I did the overflow type w/ recirculate back to radiator . I'm going to check pressure in radiator next.
Thanks,Cole
Bob
fuel anti spill valve for gas tank jbinwa General Rodding Tech 2 09-16-2007 08:57 AM
Antifreeze MI2600 Engine 9 08-09-2007 08:07 PM
Antifreeze MI2600 Engine 10 05-10-2005 03:25 AM
Help! Coolant spill on new floor! Carbed95GT Garage - Tools 4 01-11-2004 06:01 PM
Antifreeze Leak bigjoedo Engine 4 04-03-2003 02:42 PM
