Keith Black makes some d dish pistons that can be purchased from summit,they work great with vortecs.
Shane |
I did some lengthy research and found that all 5.7 Vortec engines (only came in trucks) had fully dished pistons - nothing with flat tops or D shaped dish, and even the GM crate Vortec engine with 9.1 cr requires 91 octane which bears that out. SBC engines have been built that ran fine on 87 octane and 9-1+ comp ratio with good quench from Vortec heads and quench type pistons.
So the only way to get a decent quench in any 350 SBC is to change pistons, and even with the inexpensive Sealed Power / Speed Pro type hypereutectics that would run well over $300 by the time I pay machine costs, not to mention R&R & the work on the engine which I wouldn't do if I don't change pistons. And available D shaped dish pistons are significantly more expensive. And calculting comp ratios with available inexpensive pistons and the largest (67cc) comb chambers available on low cost aftermarket Vortec heads, I'd still likely have to run at least 89 octane, so wouldn't be gaining much in the way of reduced gas costs, if anything. Figuring a max miles on that car during my retirement at 50k miles, if I leave the stock shortblock alone, except for a cam change, it will cost less to use the small chamber 64cc heads and run 91 octane than changing pistons. Not to mention all the work. And I'd probly gain a few lbs of low and mid range torque from increased timing advance and slightly higher compr ratio, and maybe even a mpg or 2. With 64cc heads, .02 x 4.1 coated gasket which should seal a non-machined deck, stock 9.9cc no-quench dished pistons, .05 actual deck height (.045 at blueprint block height value) = 9.09-1 compr ratio. With .055 deck height about 9.07. So as "nice" as it would be to have the more modern quench setup, it's just not cost effective for my situation. Going with the above setup saves me at least $300 up front plus a whole bunch of work, and ends up saving probly $100 or more cost over time. Last edited by macx; 01-11-2011 at 10:18 AM. |
This is like my wife setting in line at Costco to save a dime a gallon when filling up her Prius. Bogie |
9.7 with Vortecs (singh groved,polished and deburred chambers) on 87 on a 406.
Shane |
Just to update this, Any 87-93 Police caprice with the LO5 tbi 350 will have factory flat tops and be a roller engine.
This was the engine in my 90 Caprice 9C1 ...
LT-type engines came w/FT's, used metric rings.
In most cases those people who go chasing down the last mpg on anything with an sbc spend dollars to save cents. The 350 is not an ecotec 2.2L or even an LS3- accept it for what it is and go from there.
As already said the only time it makes sense to change something for mpg's is when you need to change (rebuild) it anyway. |
The L31 vortec out of my 1996 k2500 was a roller block and had flattops like the above pictures. Obviously had vortec heads as well as 4 bolt mains!! Win win. With some block decking or thiner head gaskets you could come up with real good quench numbers! Factory vortec engines are about 9.1 compression stock so plan on a bit more if decking or thinner headgaskets.
Here's a 1.560" hyper flat-top 350 piston for under a hundred bucks for a set of 8....
http://www.summitracing.com/parts/SUM-17350-30/ |
I think you'll find the stock CR higher than 9:1- my engine measured to be ~9.5:1 w/the dished pistons and a thin-ish (0.028") head gasket.
| RolLeR BloCkS WitH MECH. fuel pumps? | MikeAhrado | Engine | 13 | 08-26-2010 06:30 AM |
| Big blocks eat cams without roller lifters? | DENCOUCH | Engine | 6 | 03-08-2010 03:27 PM |
| Dished pistons and quench | KGRIFF | Engine | 7 | 04-19-2007 11:00 AM |
| Quench | Steve B | Engine | 11 | 09-05-2003 10:03 PM |
| Truck blocks vs car blocks whats the differance? | Jag Daddy | Engine | 14 | 05-31-2003 11:12 AM |
