any 3spd. a 350 turbo ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2006, 09:05 PM
hello, looking for a turbo 350 trans. are all 3 spd automatics turbos ??? need one to match a 327 .which would be a good donor car ?? thanks
Old 07-04-2006, 08:56 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
Automatic 3 spd Chevy tranies are either turbo 350's or turbo 400's. They were used in pretty much all Chevy cars and trucks from the mid 60's to the mid 80's. You can find one in just about any wrecking yard.
Old 07-04-2006, 09:10 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I believe that the TH250 transmission is also a 3 speed automatic. Crosley, or another more experienced poster will better know more definately than I do. I can tell you though, if you look at the pan for a TH350, it looks like a square, with one corner cut off. Here's a link for you for transmission dimensions.
In a while, Chet.
Old 07-04-2006, 11:20 PM
But not all Turbo 350's & 400's have a Chevy bolt pattern. Many of them have the BOP (Buick-Olds-Pontiac) bolt pattern and will not work with a Chevy engine.
Old 07-05-2006, 07:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I will mention the t-200 series of trans... they are 3 speeds , some what weak for performance use.
T-250 is a weak version of the t-350 tranny.... look at the cooler fitting on passenger side of main case. IF there is a stud with nut protruding from the case area.
IF there is a stud there it is a t-250 tranny while it looks exactly like a t-350C with an electrical connector near the shift linkage on the driver's side of case
Old 07-06-2006, 07:38 PM
thanks , and powerglide ???
thanks, for your anwsers,,abig help,, also, if i put a shift kit in a stock 2 spd. powerglide,, can it take it , or ruin it ?? i,ll probably have about 330//to //350 hp. and want to burn rubber from dead stop if it will,,if i un hook modulator hose it shifts hard like a shift kit..is this a no /no ??? thanks, again rc
Old 07-08-2006, 07:05 AM
fast68's Avatar
likes chevy trucks & boobies
there were many other 3 speed auto transmission by GM other than the 200 and 250 and 350 and 400
there was the 375 ones and TH475 ones and THM180 ones and M30 ones and some others too
lots and lots
and to make it more confusing they started changing the names of the trannies in the late 80s to early 90s
such as the TH475 to the 3L80HD and the TH400 to the 3L80, and so forth
some look like the th350 in every way to an untrained eye, such as the TH250
go here and read
http://en.wikipedia.org/wiki/List_of_GM_transmissions
good luck
Old 07-08-2006, 08:05 PM
Thanks I,ll Check It Out
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 04:54 AM
turbo 350?? +nub+ Engine 5 10-05-2003 09:22 PM
Help with Turbo 350... Jason_R Transmission - Rearend 1 09-26-2003 07:12 PM
