Any advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2013, 11:53 PM
TRLBLAZR60's Avatar
Any advice
My brother in law and I are building a. 060" over 350
flat top pistons.
P.C. HP vortec heads. 2.02 1.6 valves.
Comp 280H
1.6 roller rockers
crosswind intake
we're trying to make 400 to 430 horse on a budget
thanks for any and all advice or suggestions!
Old 03-02-2013, 12:09 AM
327NUT's Avatar
Here's the best advice I can give you....research and purchase the best parts you can afford, assemble the engine the best way you know how. Then accept the horse power that it puts out..........and enjoy it.
Old 03-02-2013, 12:22 AM
thinwhiteduke's Avatar
Living In The Past
Use Comp 282S instead of 280H
Duke
Old 03-02-2013, 12:31 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Help us to help you by telling us the intended use.
Old 03-02-2013, 12:41 AM
TRLBLAZR60's Avatar
More of a street machine than a race car. But not a daily driver.
71 chevelle malibu.
Old 03-02-2013, 07:50 AM
vinniekq2's Avatar
budget? what is the budget
flat top pistons.
Comp 280H
1.6 roller rockers
crosswind intake
everyone has a budget,,,
do you want more horse power or lower costs?
where is the priority.
cheapest engine is to just buy a rebuilders 350 vortec with a slightly more aggressive cam,if they will allow and still give warranty,
then add a typhoon intake
decent carb 650 cfm
1 5/8s headers
drive it
add 3.36 gears and a 2200 stall converter if you want spirited acceleration with an auto
Old 03-02-2013, 12:38 PM
TRLBLAZR60's Avatar
We'll pretty much out of money for a min. He already ordered the. Is
heads new from a private party. I hand lapped the valves in. Installed the heads a daddy intake yesterday. As for the cam it's in. The rockers he already has. I wanted to build ad close to a performer rpm engine with the components he had. He knows he will need a stall. As for carb he had a 600 eddy. Would a tha650 Jolley be sufficient?
Thanks guys!
Old 03-02-2013, 12:48 PM
TRLBLAZR60's Avatar
Has anyone used the FEL-PRO 1255 intake gaskets? On this combination?
I had a little trouble with this. Intake was a little tough to line up. I'm hoping these thicker gaskets will seal.
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 03:21 PM
looking for help advice 65 C-20 Introduce Yourself 1 10-01-2011 12:05 PM
I'll need advice... zcinc Introduce Yourself 2 04-13-2007 11:48 AM
need advice redslate Introduce Yourself 2 04-07-2007 01:15 PM
