Any alignment Gurus on The Site? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2013, 07:24 PM
Greg T's Avatar
www.krusinklassics.net
I have a 96 C1500 short box with a 4/6 drop kit and 275-45R20 rollers all the way around. After doing the drop kit (dropped spindles and rear axle flip) I had the front end aligned. BUT, I never gave the specs any thought. After thinking it over I realized that the much larger contact patch of these fat tires is going to require much different alignment specs than stock. Back in the 80s I was actually state certified in front end alignment and repair, but have not kept up on the newer stuff as my career took a different path.
After giving this some thought, I came up with the specs of 2.0 degrees of positive caster, 1 degree negative camber, and about 1/8" toe-in. This should maximize the contact patch, I would think. If there are any gurus to correct my ideas please chime in!!
Thanx much!
Old 08-05-2013, 07:59 PM
LATECH's Avatar
2 degrees caster isnt enough . It would make the car a struggle to drive on a straight road.
Factory spec is best for that.
Factory on camber, leaning towards the positive side of the tolerance would be ideal.
Toe in would be the angle I would alter. Maybe a tad more toe in than stock as the larger wider tire will make a little more drag and load the suspension a little harder, causing more spread in the front to rear measurment at road speed.
Nice truck BTW.
Fact is stranger than Fiction
Old 08-05-2013, 10:38 PM
Greg T's Avatar
Thanx much. She runs very well with a nicely massaged 388.
So, about 4* caster, -0.5* L camber and 0.0* R camber, 3/16" toe?
junkyard gurus, I need help! ap72 Hotrodding Basics 17 12-01-2012 07:49 PM
for edelbrock gurus RotorHead Engine 5 10-19-2011 02:17 PM
camshaft gurus help? chevy302builder18 Engine 2 09-13-2011 05:12 AM
Any International Gurus? (IH) rustycarr Hotrodders' Lounge 5 06-07-2010 12:01 AM
Blower gurus HELP please! DUKEOFBLUZ Engine 5 03-04-2006 09:06 AM
