any blower/nitrous guys running ngk 5671a-11 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 03:43 AM
menoaz's Avatar
Currently im running the -9. Does anyone see any differance in the 9,10,11 cold plugs?
The -9 is already a really cold plug. I have mine gapped at .25.
I have a 427bbc 8.75 compression forged piston running a 8-71 with 7lbs of boost.
I have a msd6al, and 2 850,s on top. Should i stick with the -9 or go as cold as possible and run the -11. This is a all out drag car.
Old 11-06-2012, 09:19 AM
hcompton's Avatar
Old & Furious
What type of problems are you having? Was it stumbling or knocking under throttle. Or just preparing for the hot days of summer.
Hotter plugs are better if you can run them without knocking or pre-ignition.
Old 11-06-2012, 12:23 PM
menoaz's Avatar
No problems yet, i have not takin it to the track with the 8-71. just curious if i should go to the coldest plug when running 7lbs of boost.
Old 11-06-2012, 10:37 PM
blwilliams's Avatar
We run NGK 5671 -10 on the blown alky 565 BBC we run 40+ pounds of boost via the PSI 14-71 Hi-Helix blower.
I don't think you need that cold of a plug.
Are you having any problems with detonation?
How much total timing are you running, what fuel?
blower guys running no power valves only sees track menoaz Engine 15 03-25-2013 01:12 AM
blower intercooler??? blower guys? HemmiGremmie Engine 4 04-19-2012 07:19 PM
327 Blower Or Nitrous? backyard71nova Engine 6 04-14-2007 06:56 PM
Will A blower cam work with nitrous. 73camaro Engine 3 09-24-2006 01:59 PM
blower je pistons, nitrous capacity? 84Z Engine 11 08-31-2006 02:23 AM
