-   -   any body heard of pro comp heads for ford small block (http://www.hotrodders.com/forum/any-body-heard-pro-comp-heads-ford-small-block-119886.html)
mustang joe 07-10-2007 08:19 PM
just bought a set of 225cc fully cnc ported 2.05 intake valve and 1.60 exhaust valve 1.6 roller rockers with a comp roller cam with 564 lift all going on a 302 with mahle pistons i was just wandering how pro comp performs if any body could give me a response it would be grately appreciated thanks
DoubleVision 07-10-2007 08:27 PM
From what I understand, these are the made in china claimed to be aussie made heads from who knows what kind of metal that says it`s aluminum. Most of the reviews I seen on these heads were not good, few rated them okay. You must be planning on revving it to the moon with a cam and ports that big, otherwise it`s going to be real soggy in a little 302 until it revs to about 4500 or so. I hope this is a strip car your building, still it`ll need really low gears.
mustang joe 07-10-2007 08:34 PM
i got low gears
3800 stall with c4 4.11 gears in the rear will only be a strip car also i put a parker funnel web intake on it
