Any cam guru's or engine builders? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2010, 12:48 PM
I am trying to degree a small voodoo hydraulic roller cam (60110) for my truck and the cam card specs are intake opens -0.5* BTDC @0.50 (so in effect it actually hapens after TDC correct?)
and intake closes 31.5* ATDC@ 0.50
I have double checked my actual TDC and when i check cam with degree wheel and dial indicator I was getting intake open@ -5* ATDC and close@ 36*BTDC
Using the Cloyes hex-adjust the only option is either 6* advance or 4* advance so I went 4* advance and now have intake opening @1* btdc.
Would 6* be better?
Can anyone tell me if this sounds right the -.5 is a strange figure to begin with. Thanks in advance. (no pun intended)
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Engine Choice, Please Help savman1 Engine 1 01-12-2006 09:36 PM
New Engine build, is cam gear one tooth off? fordSR Engine 16 12-15-2003 05:05 PM
