Any drawbacks to larger Ujoints? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2007, 08:38 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
I'm having a driveshaft built for a custom T56 install and I was wondering. The stock setup used 1310 Ujoints. I was going to upgrade to 1330, and I'm finding lots of 1350 yokes as well. Any reason not to go overkill with the 1350s? Its going in a 96 impala SS, 8.5" rear with 4.10s, engine is a 383 LT1 making about 400 at the crank.
Old 09-28-2007, 09:33 PM
As far as driveshafts go, bigger IS better, especially if you have the driveshaft tunnel room. Why limit yourself to the torque potential of the driveshaft joints???
Old 09-28-2007, 10:35 PM
Agree
I agree. If there is no huge cost or weight increase then bigger is better.
Old 09-29-2007, 01:33 AM
curtis73's Avatar
Wiki Edits: 16
Ok, that's what I thought. Thanks for confirming.
The project in mind is a viper T56 that I modified with a GM front adapter and tailhousing, but kept the viper output shaft. Upgrading to a 1350 output yoke is no more expensive, and the rear is going to be torn apart for a ring and pinion and bearings so installing a 1350 yoke there is just a matter of a $40 difference.
Thanks
Adding larger nozzle to Sand Blaster? beemdubya Body - Exterior 3 02-02-2007 10:02 AM
larger injectors? ap72 Engine 1 09-04-2006 12:58 PM
Problem batch loading larger images cboy Hotrodders Site Suggestions and Help 10 03-23-2005 08:26 PM
reducing detonation by running a larger cam fiscus Engine 2 03-09-2004 05:21 PM
fun with larger engines in 87-89 Mustangs? WayOutCat Engine 4 05-12-2003 08:29 AM
