Any first hand experience on leaf spring repairs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2004, 08:08 PM
New Member
I posted earlier about new rear leaf springs for my Caddy and Joe replied about having them redone at a local shop.
I've heard good and bad about having them fixed. Any first hand accounts on the good or bad?
Thanks,
Eric
Old 06-12-2004, 03:59 AM
aka Duke of URL
Arrow
-Re-Arching Leaf Springs-
In my opinion, the process is attune to my trying to revive my sex life with a can of FIX-A-FLAT with the wand stuck up my butt. Ain't gonna work no matter how much you want it too...
Old 06-12-2004, 10:45 PM
I had the mono-leafs on a '69 Nova rearched at a local shop back around 1971, & it still sits like it should, although it has not been driven much since then.
Old 06-13-2004, 12:02 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
all i know is i have done LOTS of them WITH OUT ever having a problem, the key thing is they cant be rusted to the point were the rust scale fall off in big pieces, surface rust is ok. heck the shop i worked at use to have BIGG truck leaf spring rebuilt
Old 06-13-2004, 10:17 AM
4 Jaw Chuck's Avatar
With what a new set costs why would you bother?
— Han Solo
Old 06-13-2004, 10:34 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
A reached spring is just as good as a new one and a lot cheaper.
for the cars that you can't get them anymore they can make new ones.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 06-13-2004, 07:24 PM
Wiki Edits: 5
just to give ya an idea chuck, i had a set rebuilt for a friends truck they wanted over $300 for the pair to make new ones, but only charge me $150 to rebuild, re-arch & add 2 more springs to her original set....joe
Old 06-14-2004, 12:12 PM
willys36@aol.com's Avatar
Wiki Edits: 21
The 70 year old springs on my Willys are re-arched originals and still going strong! A lot cheaper that new springs 'cause I assemble them myself so all I pay for is the re-arching service. I use grade 8 allen-head cap screws (5/16" - 7/16" depending on the hole in the spring) instead of the expensive custom spring bolts the spring guys sell.
Old 06-14-2004, 01:17 PM
EBlack36's Avatar
Rebuilt Excitment
I had the ones on the 36 done in 98, they added a couple of leaves, lined them with teflon, and used the metal clamps on them to prevent the springs from turning and only paid a buck and a quarter ($125.00).
