Any Gen III gurus? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2007, 08:18 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Any Gen III gurus?
I've been told that when swapping the cams in the Gen III V8s you don't need to pull the lifters. All that needs to be done is back off the rocker arms and rotate the engine through two revolutions. I guess doing this will lift all of the lifters into a retainer and hold them up enough to remove the cam? Is this true? I found a Comp Cam that should work nicely in my truck and not pulling the lifters would make the job a little quicker and easier since the intake wouldn't have to be removed.
Old 04-27-2007, 08:53 PM
Bumpstick's Avatar
Hammer and a torch
Answer...Yes... Hey not a Guru but do know that is correct about the cam change...
Old 04-27-2007, 09:03 PM
Blazin72's Avatar
Wiki Edits: 19
That is pretty cool.
6.0 Gen III 61Burb Electrical 1 03-14-2007 11:53 AM
Cold knock issue with Gen III SBC`s...? Bumpstick Engine 14 04-09-2006 09:34 PM
How does a Gen III SBC oiling system differ from Gen I/II systems? 70bird Engine 1 04-09-2006 02:13 PM
GM Gen III/IV V8s Blazin72 Engine 14 10-05-2005 08:44 PM
Gen I vs Gen II question Mrfixmaster Engine 4 05-05-2004 06:31 AM
