Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - any good air drill with variable trigger?
Old 02-26-2012, 09:28 AM
tech69 tech69 is online now
put up or shut up
I don't think it's possible for them to have more torque due to being powered by air flowing through vanes, which means at the lower rpms it won't have the torque, where as a powered one would be more consistent throughout, but I'd like to think that the higher quality airdrills MAY be somewhat compareable to the powered ones. So which air drills do you have? do you have an IR one? On a side note, I would think that if more air drills had a lever instead of a trigger that also might help it trigger a little easier. You see those levers on the angled air drills but not normal drills but I have a feeling that could help as well.
